Skymike
May 23, 2023Aspirant
RAX30 How to increase UDP timeout for Voip
I have recently installed RAX30 AX2400 for general use and Voip. The Voip by Gama is not working correctly and the software supplier advises that the UDP timeout needs to be increased to 300 secs. ...
- May 23, 2023Unless you gain access to the command line of the RAX30 using telnet & co, it is not possible to change UDP or TCP timeouts.
May 23, 2023Guru - Experienced User
Give the DMZ of the router a try.
Skymike
I appreciate the thought but (a) I am limited by the VoIP software provider; (b) I am not competent to fiddle in the black box ; and (c) I am running a small publishing business here and I am not keen on the potential increased risk in using a DMZ server. Thanks for taking the time.
- FURRYe38May 23, 2023Guru - Experienced User
DMZ would only be configured on the NG router. Just as a test to see if it works.
Risk is low for VoIP devices in the DMZ. Not much to hack there.
