moreplovac
Oct 23, 2024Aspirant
RAX30 in AP mode and Paloalto firewlal setup
 Hello,     wondering if anyone has experience setting up RAX30 in AP mode connected to PAloalto firewall.  There is a PA article explaining it (and use VLAN to connect wifi device) but would like to ...
- Oct 23, 2024
Thank you for your reply; i find it more easily to just use router in router mode, connect Internet port to firewall' available port, setup IP on firewall port and make sure all policies are up to date.
So my setup looks like this:
RAX30 WAN port (10.1.1.222/25, GW 10.1.1.1) ---->>---- PAN Eth3 (IP assigned 10.1.1.1), in zone WIFI; added to default router. Sec policies configured accordingly. NAT policy use the same Internet facing IP as PAN' WIRED zone.
RAX30 (WIFI) IP 192.168.1.1, clients are getting IPs from dhcp range 192.168.1.2-50.
No issues with internet access.
Thank you again for comments.
Oct 23, 2024Guru - Experienced User
You'll need to make contact wth the Mfr of that firewall for there help and support with there product.
Here is article for configuring the RAX for AP mode:
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
