SA_Penguin
Apr 30, 2022Tutor
RAX30 Locks Up
Every 2 to 3 days, my RAX30 router locks up.
Indicator lights say all is OK, ping works (192.168.1.1) BUT put that in a web browser, and either get a timeout or "connection refused".
This can be fixed by power cycling the router.
That's OK for a short term solution, but gets stale after about a week. I've been doing this for over 2 months.
Router Firmware Version V1.0.6.74_1
1. what modem/gateway is it connected to?
2. Looks like that firmware released in march. Have you tried a factory reset? If that doesn't help, you can try downgrading the firmware a version and see if its related to the version you're on
Here In Australia, we Have NBN. In my case, that means Ethernet To Utp Adaptor In-house.
I Will Need To Look Up How To Do A Factory Reset / Firmaware Downgrade. Do You Have A Link?
This Stupid Tablet Insists On Capitalising Every Word (Sigh)...
to factory resets, push and hold resets for 7-15 seconds while the device is powered on.
If that doesn't help, then try the downgrade. Downgrading is pretty simple. you download the firmware version you want from the support site, then follow the manual update process (in the manual) but use the firmware you downloaded and not new firmware.
