Nick8810
Dec 02, 2022Tutor
Rax30 Nighthawk
The Wi-Fi keeps dropping. The Wi-Fi signal is strong, have not had a problem for about 6 months till now. The wired connections work with no problems. Any suggestions to fix the problem? Using the 2....
Dec 03, 2022Guru - Experienced User
It only happens on the 2.4ghz side?
Have you tried changing what channel you broadcast on? 2.4ghz is sensitive to interference and maybe something is broadcasting on it.
