stevepski
Jul 04, 2022Aspirant
RAX30 Port forwarding
Just upgraded from an R7000 to an RAX30 (due to unrelated wi-fi issues). Hosting an ARK server - ports were forwarded on the R7000, worked for years. Forwarded ports on the RAX30, cannot access game ...
Jul 06, 2022Guru - Experienced User
Is uPnP disabled on the router?
stevepski
Jul 06, 2022Aspirant
The RAX30 is connected only to my Motorola MB7621 modem. (Xfinity ISP)
I have tried uPnP enabled and not enabled. Should this make a difference?
Last night I disconnected the RAX30 and re-connected my old AC1900. Everything worked perfectly (except for the 5GHz phone connection, which is why I chose to replace the router in the first place).
Never needed to use DMZ or change any settings on the PC firewall with the previous router. I could see my ARK server and connect to it. Disconnected the AC1900, re-connected the RAX30, performed a factory reset, forwarded my ports, re-booted my ARK server, and nope - could not see it or connect to it through the internet selections. But I found out that I could see my server on the LAN portion of the ARK screen, but not on the internet side. So I can play on my server, just nobody outside of my home network.
- iyangJul 07, 2022NETGEAR Expert
- stevepskiJul 08, 2022Aspirant
I have attached a picture with the ARK server setup and my RAX30 settings. These are the exact same settings I used on my previous R7000/AC1900 router. Is there a setting somewhere to actually turn on the port forwarding? Or just add these rules?
- microchip8Jul 09, 2022MasterIf port forwarding isn't working for you, why not put the server in DMZ?
