stevepski
Jul 04, 2022Aspirant
RAX30 Port forwarding
Just upgraded from an R7000 to an RAX30 (due to unrelated wi-fi issues). Hosting an ARK server - ports were forwarded on the R7000, worked for years. Forwarded ports on the RAX30, cannot access game ...
stevepski
Jul 06, 2022Aspirant
The RAX30 is connected only to my Motorola MB7621 modem. (Xfinity ISP)
I have tried uPnP enabled and not enabled. Should this make a difference?
Last night I disconnected the RAX30 and re-connected my old AC1900. Everything worked perfectly (except for the 5GHz phone connection, which is why I chose to replace the router in the first place).
Never needed to use DMZ or change any settings on the PC firewall with the previous router. I could see my ARK server and connect to it. Disconnected the AC1900, re-connected the RAX30, performed a factory reset, forwarded my ports, re-booted my ARK server, and nope - could not see it or connect to it through the internet selections. But I found out that I could see my server on the LAN portion of the ARK screen, but not on the internet side. So I can play on my server, just nobody outside of my home network.
iyang
Jul 07, 2022NETGEAR Expert
- stevepskiJul 08, 2022Aspirant
I have attached a picture with the ARK server setup and my RAX30 settings. These are the exact same settings I used on my previous R7000/AC1900 router. Is there a setting somewhere to actually turn on the port forwarding? Or just add these rules?
- microchip8Jul 09, 2022MasterIf port forwarding isn't working for you, why not put the server in DMZ?
- stevepskiJul 09, 2022Aspirant
I tried that, but I'm really not familiar enough with DMZ to know if I did it correctly. But the thing that really puzzles me is that my old Netgear router (R7000) did not need it, that router forwarded my ports easily. Nothing else has changed except the router.
