TomCo_1
Apr 04, 2024Follower
RAX30 Two Factor Authentication (2fa) is not requiring a code from the request phone.
There is no documentation in the User Manual that I can locate. Anyway, iPhone / (dropdown) Account Management / 3 choices: Edit Profile / Login Settings / Delete My NETGEAR Account; Select Login Se...
- Apr 04, 2024
You posted this in the ReadyNAS forum area (not the right forum for routers)
schumaku
Apr 05, 2024Guru - Experienced User
Convinced a moderator is able to move your post to the more appropriate Nighthawk With WiFi 6 (AX) And WiFi 6E (AXE) Routers to discuss Nighthawk (RAX and RAXE Series) router products.
