carterbrandon
Apr 08, 2023Guide
RAX30 WAN port speed only 100M
My RAX30 (Firmware V1.0.10.94_3) shows in the stats that its WAN port is connecting at '100M/Full'. This is when trying several CAT 5e cables (and a short CAT6) between router and ONT which achieve '...
michaelkenward
Apr 08, 2023Guru - Experienced User
carterbrandon wrote:
There don't seem to be any settings on the RAX30 UI which would allow the speed to be manually set.
It reports what it sees.
Have you tried the obvious first step and reset the RAX30?
What is this ONT? They rare come with much more than an Ethernet connection, but some are a bit more complicated.
