carterbrandon
Apr 08, 2023Guide
RAX30 WAN port speed only 100M
My RAX30 (Firmware V1.0.10.94_3) shows in the stats that its WAN port is connecting at '100M/Full'. This is when trying several CAT 5e cables (and a short CAT6) between router and ONT which achieve '...
michaelkenward
Apr 08, 2023Guru - Experienced User
carterbrandon wrote:
There don't seem to be any settings on the RAX30 UI which would allow the speed to be manually set.
It reports what it sees.
Have you tried the obvious first step and reset the RAX30?
What is this ONT? They rare come with much more than an Ethernet connection, but some are a bit more complicated.
carterbrandon
Apr 08, 2023Guide
The ONT is the standard (Huawei?) ONT suppiled by BT Openreach for domestic FTTP setups. Within its lifetime, the router has had lots of restarts, and at least one factory settings reset, followed by a config restore from backup, but I'm certainly happy to give that another try.
- michaelkenwardApr 09, 2023Guru - Experienced User
Not always a good idea. That can bring back from the dead the issue that caused problems before the reset.
There seem to have been several of those.
I assume that you aren't using one of BT's smarthubs.
- carterbrandonApr 09, 2023Guide
No smarthub, whatever that is. With Aquiss. Just my own router and the ONT.
I'll try the reset without the restore if I can. The wizard immediately following the reset steers you towards it, but if I can swerve it, there may be a window of being able to see the status pre-restore.
It is the box that BT supplies to connect to the ONT.
