0019wild
Oct 17, 2024Follower
Rax30 wifi
Can this router be connected to the internet without a cable?
How does the Internet get to you?
As Kitsap says, you usually need a modem. The only way in without that is if the ISP delivers the Internet over an optical link to your front door. Then you may have an optical network termination (ONT). That will come with a socket that takes a LAN cable like the one that can feed the WAN socket on your router
Anything else needs a modem.
Just another user with time on their hands.
