trljcl
Nov 18, 2024Aspirant
RAX30 wireless bridge mode dropouts
Hello, I bought a RAX30 2 days ago, as a wifi6 router to work in wireless bridge mode. This is to provide a wireless bridged connection to my main wifi6 router (a virgin media hub5), about 30ft away ...
trljcl
Not sure waht channel in is - it is Virgin Media Hub 5. It does give out a really good 5 ghz (== reasonable range) signal - better than my previous routers. I can login and try turning band optimization / steering off, and try to fix it to one 5 ghz band (like 36) if that would help?
Nov 18, 2024Guru - Experienced User
I'm just recommending avoiding dfs channels. they can create instabilities if there's any radar/weather radar/dfs broadcasts in your area.
