Barbaramcgrorey
Dec 11, 2022Aspirant
Rax30
Internet is blocked
Dec 11, 2022Guru - Experienced User
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Try a factory reset and setup from scratch with a wired PC and web browser.
