Krackerjax's avatar
Krackerjax
Follower
Dec 17, 2022
RAX30
How can I hook up my computers direct  and still leave the router WIFI on for the TV s
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Not sure that I follow the question. If you want to connect a computer to the router, just plug it into one of the four the LAN ports on the back.
    That isn't connected to how the WiFi works. LAN and WiFi happily ignore each other.
    You could even plug the TV into the router, if it supports a LAN connection.
