Drskhan
Aug 22, 2023Aspirant
RAX30
Hi How rax 30 is compared to rax 70 in terms of coverage through the house including garage and garden ? I previously had rax 120. Returned it after 2 days as it was repeatedly rebooting like nuts...
Aug 22, 2023Guru - Experienced User
What's the size of the home in Sq ft.
RAX30 is fairly entry level and probably not great for larger sized homes.
Review the spec sheet for each of the models your looking at for wireless specs and speed information and handling.
https://www.netgear.com/support/
There is a FW fix for the RAX120 reboot issue.
- DrskhanAug 31, 2023AspirantThanks but it was too technical fix for a person like me. But thanks anyway.
These are the dimensions:
House – 10m x 7.8m
Garden – 10.7m x 9.8m
Garage – 5.8m x 3.1m
I guess 310 sq m or 3336 sq ft.
Regards
Dr Shaz
