Drskhan
Aug 22, 2023Aspirant
RAX30
Hi How rax 30 is compared to rax 70 in terms of coverage through the house including garage and garden ? I previously had rax 120. Returned it after 2 days as it was repeatedly rebooting like nuts...
Aug 23, 2023Guru - Experienced User
Distance wise, most single router solutions are going to be pretty similar as they've all been maxing out their wifi broadcast power for years. You might get some differences in performance at those ranges on the higher end models but their actual coverage will be similar.
If you're needing to cover dead areas, maybe switching to a mesh system with a satellite would help versus a single router solution. How big is the home?
- DrskhanAug 31, 2023AspirantThanks
House – 10m x 7.8m
Garden – 10.7m x 9.8m
Garage – 5.8m x 3.1m
I guess 310 sq m or 3336 sq ft.
Regards
Dr Shaz
