Drskhan
Aug 22, 2023Aspirant
RAX30
Hi How rax 30 is compared to rax 70 in terms of coverage through the house including garage and garden ? I previously had rax 120. Returned it after 2 days as it was repeatedly rebooting like nuts...
Aug 23, 2023Guru - Experienced User
Distance wise, most single router solutions are going to be pretty similar as they've all been maxing out their wifi broadcast power for years. You might get some differences in performance at those ranges on the higher end models but their actual coverage will be similar.
If you're needing to cover dead areas, maybe switching to a mesh system with a satellite would help versus a single router solution. How big is the home?
Drskhan
Aug 31, 2023Aspirant
Thanks
House – 10m x 7.8m
Garden – 10.7m x 9.8m
Garage – 5.8m x 3.1m
I guess 310 sq m or 3336 sq ft.
Regards
Dr Shaz
House – 10m x 7.8m
Regards
Dr Shaz
- FURRYe38Aug 31, 2023Guru - Experienced User
The RAX70 should be good enough for that size of home.
- DrskhanAug 31, 2023AspirantAnd RAX30 is not going to cover that much area ?
Thanks - DrskhanAug 31, 2023AspirantThanks
And how RAX70 is different from RAXE300 ?- FURRYe38Aug 31, 2023Guru - Experienced User
The RAX30 is fairly low budget router so may or may not have the same coverage as the RAX70 or 120.
RAXE has 6Ghz frequency support were the RAX series does not.
