Brookelovas
Feb 22, 2024Follower
RAX30
Router won’t connect to the internet. The light for power instead but no other lights are showing. I’ve tried to reset, and unplug. No internet connection
Feb 22, 2024Guru - Experienced User
What color is the power light?
When you reset, did you push and hold for 7-15 seconds while powered on?
What modem/gateway is it connected to?
