NathanTPerk
Jul 18, 2022Aspirant
RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router is stuck in bridge mode
I turned the bridge mode setting on for my RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router. Now I cannot access that admin panel. I have tried the factory reset, but when I try, none of the lights cha...
Jul 19, 2022Guru - Experienced User
When you're resetting, are you pushing and holding reset for up to 30 seconds while powered on?
- NathanTPerkJul 19, 2022AspirantYes. I hold it down and none of the lights change to indicate a factory reset. I have held the button down for every increment of time you can think of.
