NathanTPerk
Jul 18, 2022Aspirant
RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router is stuck in bridge mode
I turned the bridge mode setting on for my RAX35 — Nighthawk AX4 4-Stream WiFi 6 Router. Now I cannot access that admin panel. I have tried the factory reset, but when I try, none of the lights cha...
NathanTPerk
Jul 19, 2022Aspirant
What do you mean I don’t have to reset it to factory settings if I find the ip?
I found the ip when I used an ip config command or on my Mac when I login into the network.
When I use any web browser to try and open the admin panel, it still doesn’t work. Do you have any suggestions for an ip scanner on macOS. Angry IP Scanner does not work because it’s developer certificate expired.
schumaku
Jul 19, 2022Guru - Experienced User
With this WAX35 in question connecting to the network in whatever way - to another device with a link to your LAN and the default gateway of the unknown other router, yes.
IP config shows the address(es) of the adpter(s) on your MAC, as well as the default gateway, the operational router LAN IP typically.
Use ... crystal ball?
- NathanTPerkJul 19, 2022Aspirant“With this WAX35 in question connecting to the network in whatever way - to another device with a link to your LAN and the default gateway of the unknown other router, yes.”
1. Yes, but this still isn’t getting me to the admin panel. I need to access the admin panel to turn off bridge mode. Is there another way?
2. Sorry I should have made it clearer, I used windows ipconfig command and on MAC in network preferences you can easily find ip of network your connected to.
3. What is crystal ball?- schumakuJul 19, 2022Guru - Experienced User
NathanTPerk wrote:
1. Yes, but this still isn’t getting me to the admin panel. I need to access the admin panel to turn off bridge mode. Is there another way?Still no idea on how the WAX35 was operated and configured before to provide a workable environment.
NathanTPerk wrote:
2. Sorry I should have made it clearer, I used windows ipconfig command and on MAC in network preferences you can easily find ip of network your connected to.This gives the PC resp Mac adapter IP, the default gateway IP (which isn't the WAX35 unless I'm missing something), the subnet mask.
NathanTPerk wrote:
3. What is crystal ball?https://en.wikipedia.org/wiki/Crystal_ball A crystal ball, also known as an orbuculum or crystal sphere, is a crystal or glass ball and common fortune-telling object. It is generally associated with the performance of clairvoyance and scrying in particular.
