darkneil14
Jul 10, 2020Aspirant
RAX35 - Bricked after installing the latest firmware
After installing the latest firmware on my RAX35 at first the wifi won't turn and then i did restart, now it won't even connect to the internet and wifi is also not turning on. I am unable to configu...
Jul 11, 2020Guru - Experienced User
What modem is it connecting to?
What are the led's on it doing?
You don't need internet to access the routers gui. You should be able to connect/navigate by hardwiring into it.
What firmware did you try to install? Did you do it via the app or hardwired? (I'd recommend hardwired for firmware updates)
Have you just tried starting over and factory resetting? Pushing and holding the reset button for 7-15 seconds while its powered on?
darkneil14
Jul 11, 2020Aspirant
