pilon29
May 09, 2020Initiate
RAX35 - Confused about installation
Folks This may be a stupid question and I apologize. I just installed the RAX35 Router and realized it came with a CAT 6 Cable but no phone cable and there is nowhere to plug the line from the wa...
May 09, 2020Guru - Experienced User
The RAX35 is a router only. it isn't a modem. If you have dsl, you'd need a dsl modem.
If you're prior setup was a dsl modem/router device then you might still need to use that device but place it in modem only/passthrough mode.
- pilon29May 10, 2020Initiate
Thank you very much. I found the instructions to set it to modem only.
