RangerX
May 29, 2021Apprentice
RAX35 / RAX40 Missing Remote Management ability FW 1.0.3.94
Updateded from FW 1.0.3.88 to 1.0.3.84 two weeks ago. Noticed today that the Remote Access Management page is gone and replaced with Web Services Managment page. The new Web Services Management ...
Xxracer2005xx
Jun 14, 2021Initiate
Yeah, I am having the same problem. It just flashes and goes away. It does the same thing with attached devices when I go into one, theres a priority setting that flashes and goes away.
- RangerXJun 22, 2021Apprentice
@Christian_R replied to my post. His response was that the Remote Management function is End of Life. I take it that means it will not be fixed and will no longer be available. He didn't specifiy if End of Life was for all Netgear routers or just the RAX35/Rax40. I'm guessing that there are vulnerabilites with the Remote Management function on this router and Netgear has decided it is easier to disable the function than to fix it.
After always buying and recommending Netgear products because they once made great home and small business routers, I won't be buying or recommending them anymore because of their unreliable products, terrible quality control, and horrible customer support.
