crewsn01
Dec 20, 2019Tutor
RAX35-100NAS
I need help with conncecting to my my Nighthawk AX4. Work computer can't see my wifi. Unable to make it find it.
- Dec 21, 2019
schumaku wrote:
...the device makers are often years behind.
Especially when it comes to chipset drivers for embedded devices that are built into the motherboard.
michaelkenward
Dec 21, 2019Guru - Experienced User
Can other devices see your wifi?
What is this work computer?
- crewsn01Dec 21, 2019Tutor
Yes, my personal laptops, phone and tablets but my work laptop (Dell) cannot see my router. I replaced my old router with a new one and when I try to see available wifi networks, my wifi router does not show up or appear. I do not know how to make it available for selection.
Thanks,
- michaelkenwardDec 21, 2019Guru - Experienced User
This tells that there is nothing wrong with your router. It is doing its job and sending out wifi.
The problem is on the receiving end.
Work laptops are sometimes locked down so that they cannot get into "unsafe" networks. (I have even seen "superglued USB ports on government PCs.) ) If it cannot even see the wifi from the router, maybe that's the problem.
Ask the people at work. They supplied the thing.
Have you tried plugging the laptop into the router? That would confirm that it is the wifi behind the problem.
Yes I have hard wire it and can get to the internet but swithching it back wifi will not allow it to show up. Saw another thread on this site and they mentioned that it may be the network adapter not being the latest and would require another adapter to be installed or updated. Tried that but I do not have administrative rights to allow the download. Will have to contact work IT again and see if they can do it and see if that will allow it to find my router.
Thanks
