JCM88
Nov 13, 2019Follower
RAX35 and RAX40
ON NETGEAR WEBPAGE RAX40 PAGE SAY THIS ROUTER IS SUITED FOR SMALL TO MEDIUM HOMES AND THE RAX35 PAGE SAYS MEDIUM TO LARGE BUT DO A COMPARISON AND THEY SAY THE EXACT OPPOSITE WHICH ONE IS CORRECT
Vores
Nov 23, 2019Tutor
Christian_R wrote:
Main difference between the RAX35 and RAX40 is that the RAX40 is equipped with a USB 3.0 port.
Christian
Is that only difference?
Vores
Nov 23, 2019Tutor
Also here it is mentioned that RAX35 has one USB 3.0 port: https://www.netgear.com/home/products/networking/wifi-routers/RAX35.aspx
- VoresNov 25, 2019Tutor
Christian_R any update on this?
- Christian_RNov 25, 2019NETGEAR Employee Retired
Vores,
Yes, that will be the difference between the 2 routers. Thanks for bringing this to my attention. I'll have the document forwarded to the team for review.
Christian
- VoresDec 06, 2019Tutor
No difference related to any other hardware, right?
- PeicDec 24, 2019Tutor
I can confirm that the RAX35 does not have a USB port. I bought one and just looked at the back.
- VoresDec 25, 2019Tutor
Thanks. How is the product?
- PeicDec 27, 2019Tutor
I'm happy with it, but do a port scan as soon as you install it. Mine had a bunch of ports open besides 53 and 80. I'm trying to figure out which ones do not need to be open so I can close them. So far closing a few hasn't affected performance for what I do.
