cbondre
Jul 13, 2020Tutor
RAX35 (AX3000) causing frequent disconnects over WiFII
Hello Netgear I had purchased and installed RAX35 (AX3000) router in Dec 2019. It worked fine for past 5 months and in early June had the firmware upgraded to latest V1.0.3.80_1.0.1. Past 3 weeks...
Jul 14, 2020Guru - Experienced User
prior to the downgrade, I'd try a simple factory reset and reinstall. the RAX devices have responded well to factory reset and reinstall after firmware changes.
