DoubleIpa
Oct 14, 2020Aspirant
RAX35 cant log into router
For the last 7 days i am unable to log into router to change settings. I tired going through IP address and also the cell phone app. I have wireless and wired connection working with no problems. How...
itsmehuey
Oct 14, 2020Luminary
do you run into any errors? Internal Error 500 error page perhaps? If so, you're most likely going to need to revert back to the previous firmware version.
- DoubleIpaOct 22, 2020Aspirant
i downgraded the firmware...turned of AX and everyday the netgear router drops connection...i am unable to join new devices nor can i log in...have to perform a default reset and start over..
thanks
