Lecdia
Feb 09, 2022Aspirant
RAX35, I want to change region.
I live in Korea, and this time I bought the RAX35 distributed in the US from Amazon. There is no problem in using it, but I want to change it to the Korean region, but I can't change it because it'...
Feb 10, 2022Guru - Experienced User
The region is locked in certain regions (like north america).
You used to be able to telenet in and use the burnsku command (google it) to be able to change the region.
