RobKen
Jan 31, 2020Follower
RAX35 Interface
Anyone having the RAX35 find the interface to be poor quality, looking like what you used in 2000? The flat 2D, black and white is so sub par to other vendors and other Netgear routers. I don't understand why they can't use the same interface as their other models.
Anyone find solutions to upgrading the interface? Thx.
1 Reply
- zmonGuide
It's the same across the rest of the lineup. The previous AC routers used to have a tad bit color to them, well, at least my Orbi is like that. It's just like the black/white interface though, just with a little color. You need to remember that it is a router though, and at least on the firmware side of things, functionality usually takes precedence over looks. I used to have a Linksys WRT1900AC for a while, and while the firmware looked nice, it was a PITA to find things.
Your alternative would just be using the iOS or Android Nighthawk app.
