ssl92677
Apr 18, 2022Star
RAX35-Issues-After-Resetting-Won-t-connect-to-modem-cannot-login
plemans recommended I start a new thread so here goes.... I have two of these and neither will connect to the internet any longer... they both died within days of each other. The first un...
Apr 19, 2022Guru - Experienced User
On the unit not working, if you can log into it, try downgrading the firmware a version.
ssl92677
Apr 19, 2022Star
Yes, thanks. I was able to download a previous version (RAX35-V1.0.3.94_1.0.1) and finally re-connect to the internet (jeez).
Now to see if I can reset the SSIDs and passwords without issue and get back to work!
