jbp001
Jan 06, 2022Aspirant
RAX35 Issues After Resetting: Won't connect to modem, cannot login to routerlogin.net
Power-cycled the router. Then, on reboot, there is a solid red power light for 10 seconds, followed by a blinking red power light for ~1 minuted, eventually followed by solid green power and ethernet...
Jan 06, 2022Guru - Experienced User
Sounds like its booting up as it should.
What modem/gateway are you trying to connect it to?
