vincem1099
Jun 13, 2020Initiate
RAX35 locks up after Firmware Version V1.0.3.80_1.0.1 update
After updating to Firmware Version V1.0.3.80_1.0.1 using the router update page the router locks up and does not respond to WiFI or the Ethernet connections. Also it does not respond to pressing the...
Christian_R
Jun 17, 2020NETGEAR Employee Retired
Hello vincem1099,
May you revert back to the previous firmware version to see if your issue persists. You may also perform a factory reset and run through the setup assistant again.
Christian
