renaudje
Oct 26, 2020Tutor
RAX35 not reliable, even when going back to firmware 1.0.3.62
It is written in the Community forum of Netgear that the latest firmware 1.0. 3.80 of my RAX35 causes problems, but it was OK for me for the last 2 months (since I bought it) ... 'til yesterday eveni...
renaudje
Oct 26, 2020Tutor
What a another strange thing: RAX35 does NOT appear on the list of Nergear Router models : my AX4 corresponds to RAX40 ?! I read somewhere it was a question of USB port ?! Anyway ...
To precise my various attempts to make my RAX35 work, I forgot to mention that:
- I RESET the router to factory settings with firmware version 80. Since it didn't fixed my problem, ...
- I then downgraded from version 80 to version 62 ... with my problem still there + (like I said before) unable to modify the SSID + no internet (while I know from the modem provider lights that it's available).
- Replacing the whole router fixed everything.
renaudje
Oct 26, 2020Tutor
I gave another try this evening, doing another FACTORY RESET while using version 62 this time: everything's working fine now, I mean, I'm able to rename my SSID + internet is now working.
I'm still puzzled why my RAX35 stopped working properly yesterday evening with version 80 after 2 months without any major problem : the browser was asking a Nighthawk authorization password or something like that + WI-FI/Internet was not available constantly (with the globe notification appearing once a while at the bottom right of Windows 10)?!
Will keep you informed if it endures our daily tech life with version 1.0.3.62. -- Jean.
- renaudjeDec 10, 2020Tutor
Was hoping to find some progress regarding this firmware problem :-( Looks like there's nothing new regarding this matter.
Just want to let know to all of you that everything has been working smothly with version 62 pour the past 6 weeks after downgrading from version 80: no problem at all. I disabled the automatic firmware update so I can stay with this present stable version 62. I'm certainly not interested in installing version 80, and am hoping for a new firmware version.
I noticed with version 80 the WPA3 Wi-Fi security protocol: this WPA3 option is not available with the firmware version 62.
