AddisonGeek
Oct 16, 2020Aspirant
RAX35 Security Certificate
This morning I used Edge to connect to my RAX35 (yes, that's what shows up in the browser), and received a message that my computer doesn't trust the security certificate. Is there a way to generate a self signed cert somewhere in the router interface? I paged through the options in Avanced Setup and found no reference.
By the way, I was able to do this on my NAS from another vendor.
Thanks.
1 Reply
- microchip8Master
Why? do you not trust your own network? How did you connect? Using the Web UI at http://192.168.1.1 ?
