Rhojo
Dec 30, 2019Aspirant
RAX35 setting up with existing Windstream wifi
I am trying to set up the NETGEAR model #RAX 35 with existing Windstream WiFi. Anybody help?
Dec 30, 2019Guru - Experienced User
If you're using your windstream as the primary router you'd want to put the RAX in AP (access point mode) or you'll be in a double nat.
Your other option is to place the windstream router in passthrough/modem only mode. You'd want to contact windstream to arrange that as they'll be the experts on their device.
The support site has manuals, install guides, install videos, etc. Its a good resource.
https://www.netgear.com/support/product/rax35.aspx
Rhojo
I really don’t know what to do. What the best is. I am no good at this stuff. I called Windstream to see if I could use the router. They never offered to help me and I couldn’t hardly understand they guy anyway. He did say it was compatible.
- plemansDec 31, 2019Guru - Experienced User
If you struggle figure it out, probably the easiest solution is to place the RAX in AP mode.
You can disable the wireless on the windstream box but it isn't necessary.
Use the manual from the support site and it walks you through setting up AP mode.
