Rhojo
Dec 30, 2019Aspirant
RAX35 setting up with existing Windstream wifi
I am trying to set up the NETGEAR model #RAX 35 with existing Windstream WiFi. Anybody help?
Rhojo
I really don’t know what to do. What the best is. I am no good at this stuff. I called Windstream to see if I could use the router. They never offered to help me and I couldn’t hardly understand they guy anyway. He did say it was compatible.
Dec 31, 2019Guru - Experienced User
If you struggle figure it out, probably the easiest solution is to place the RAX in AP mode.
You can disable the wireless on the windstream box but it isn't necessary.
Use the manual from the support site and it walks you through setting up AP mode.
