TalkerWalker
Jun 30, 2021Aspirant
RAX35 UNABLE to Connect to Router Setup
Nighthawk AX4 AX3000 4-Stream Wi-Fi Router MODEL: RAX35 (Dec 2019) / Firmware: v1.0.3.80-1.0.1 Gateway Modem: (AT&T U-verse) Pace Plc / Model 5031NV-030 / DSL (unfortantly it's all I can get where I...
- Jul 02, 2021
antinode (Guru), You'e probably heard this before, but you are the GURU... my problem is solved.
I followed your steps under [I would...] in your previous reply. My RAX35 router and it's wi-fi, my AT&T Gateway setup, PC, and home LAN, and all concerned connected devices are working as I intened them to. THANKS for your help. Regards!
TalkerWalker
Jul 02, 2021Aspirant
antinode
Jul 03, 2021Guru
> [...] my problem is solved.
Thanks for the update. Glad to hear that you got it going.
