JTagorda
Dec 01, 2019Aspirant
Rax35 Wireless Bridge Mode unavailable in web gui
Can't seem to find the bridge mode and I've looked everywhere. Updated to latest firmware also
Christian_R
Dec 02, 2019NETGEAR Employee Retired
Hello JTagorda & ThePiston450,
The RAX35 currently supports WiFi Access Point. You may find more info on page 90 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/RAX35/RAX35_UM_EN.pdf
Christian
- NetUser5Dec 02, 2019Aspirant
I agree there is something wrong here. I picked up one of these (Nighthawk RAX35) routers on black friday sale and have put about 8 hours wrestling with it trying to get the AP mode to work. Anyone get it to work yet? I can set the unit up as a router and wireless clients will browse web as normal but when switching it to AP mode dhcp times out (computer self assigns IP) even though I have an edge router doing the dhcp. The other oddity is this unit registers three mac addresses and I captured all of them on the edge router connect list and set a dhcp reservation so when any of those mac addresses connected it would be assigned a certain ip address. Only during router mode will any of them show up on the edge router (which is a netgear 7450) but when switching to AP mode the unit disappears from the universe and the only way to find it is to factory reset it. Going to try setting a static IP and see if that makes a difference. All LED's are green and showing connectivity on the router but nothing gets an IP when connecting.
Replying to my own post. Reset rax35 to factory, started config over again and set to AP mode and the static ip and mac address do not show up in the edge router. I assigned to an IP not within the dhcp range so would not conflict. Lights are all green on router but no traffic passing through it. I updated to the latest firmware as of 12/2/2019. Anyone have a tech support ticket in on this yet?
- rickliu2000Dec 07, 2019Aspirant
same thing happened to me...
Hope this problem could be solved quickly
- Christian_RDec 05, 2019NETGEAR Employee Retired
Hi NetUser5,
Thanks for taking the time to post. I'd like for our support team to contact you for further investigation. If you wish to be contacted, please send me a message with your contact info and serial number.Thanks,
Christian
- JTagordaDec 05, 2019Aspirant
yes please.
