JTagorda
Dec 01, 2019Aspirant
Rax35 Wireless Bridge Mode unavailable in web gui
Can't seem to find the bridge mode and I've looked everywhere. Updated to latest firmware also
NetUser5
Dec 02, 2019Aspirant
I agree there is something wrong here. I picked up one of these (Nighthawk RAX35) routers on black friday sale and have put about 8 hours wrestling with it trying to get the AP mode to work. Anyone get it to work yet? I can set the unit up as a router and wireless clients will browse web as normal but when switching it to AP mode dhcp times out (computer self assigns IP) even though I have an edge router doing the dhcp. The other oddity is this unit registers three mac addresses and I captured all of them on the edge router connect list and set a dhcp reservation so when any of those mac addresses connected it would be assigned a certain ip address. Only during router mode will any of them show up on the edge router (which is a netgear 7450) but when switching to AP mode the unit disappears from the universe and the only way to find it is to factory reset it. Going to try setting a static IP and see if that makes a difference. All LED's are green and showing connectivity on the router but nothing gets an IP when connecting.
Christian_R
Dec 05, 2019NETGEAR Employee Retired
Hi NetUser5,
Thanks for taking the time to post. I'd like for our support team to contact you for further investigation. If you wish to be contacted, please send me a message with your contact info and serial number.
Thanks,
Christian
- JTagordaDec 05, 2019Aspirant
yes please.
- rewverDec 07, 2019Initiate
Has anyone figured this out? I just got the RAX35 I ordered on black friday and cannot setup bridge mode (which is the only reason I bought it). This is basic functionality, I cannot remember ever owning a router that could not bridge. I did check before ordering and this would suggest it is possible: https://kb.netgear.com/25599/How-do-I-set-up-my-Nighthawk-X4-to-Bridge-mode
