Indrajit
Jun 24, 2020Guide
RAX35
Recently updated the firmware, and it started dropping the wifi connections. At first, it was working for 30min-2hours, I was rebooting the router very often, I did reset few times as well. Now it is...
Indrajit
Jun 25, 2020Guide
of,
Thanks for replying. I am using Netgear CM700 modem. The LED for internet connection to modem and the router is amber. I used the Netgear app to update the firmware of the router, it failed.I downloaded tftp2.exe. latest firmware(unzipped), used Ethernet cable to connect to the router from PC and tried to update, it failed. I connected the Ethernet cable from the PC to the output of the router (not the input/colored one) during the update.
Jun 25, 2020Guru - Experienced User
Lots of things can go wrong using tftp. Maybe a descrption of where in the process its failing?
also, are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
