Indrajit
Jun 24, 2020Guide
RAX35
Recently updated the firmware, and it started dropping the wifi connections. At first, it was working for 30min-2hours, I was rebooting the router very often, I did reset few times as well. Now it is...
bringo
Jul 08, 2020Guide
the new firmware is flawed. after i upgraded it, my wifi drops every couple hours. i reverted back to the old firmware. DO NOT USE THE NEW FIRMWARE. STUPID NETGEAR they didn't test their crap
Mjnight
Aug 21, 2020Aspirant
How do you revert to old firmware?
- Christian_RAug 27, 2020NETGEAR Employee Retired
Mjnight - Refer to the article linked below and on step 5, you may select previous firmware versions to revert back to manually.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
