ShyHigh420
Nov 13, 2023Aspirant
RAX35
Got a dos attack on this router had to manually block the services port 67 and not 443 since that is dhcp and IP. So if anybody has any issues I suggest you check your logs and see if you have any ip...
- Nov 14, 2023
ok so I went with your option and did a whois and is was my isp abusing a port and sending dos attack: fraggle attacks so I ended up copying the logs to send to comcast on this website https://internetsecurity.xfinity.com/help/report-abuse they mitigated the issue now thanks for your help much appreciated
michaelkenward
Nov 14, 2023Guru - Experienced User
ShyHigh420 wrote:
Got a dos attack on this router ....
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
- ShyHigh420Nov 14, 2023Aspirant
- michaelkenwardNov 15, 2023Guru - Experienced User
Interesting.
Another interpretation would be that those reports are artefacts created by Netgear's logging system, which is known to be problematic.
- microchip8Nov 15, 2023MasterYour ISP is really not going to DoS you. It's a false positive, like 98% of the rest.
