ShyHigh420
Nov 13, 2023Aspirant
RAX35
Got a dos attack on this router had to manually block the services port 67 and not 443 since that is dhcp and IP. So if anybody has any issues I suggest you check your logs and see if you have any ip...
- Nov 14, 2023
ok so I went with your option and did a whois and is was my isp abusing a port and sending dos attack: fraggle attacks so I ended up copying the logs to send to comcast on this website https://internetsecurity.xfinity.com/help/report-abuse they mitigated the issue now thanks for your help much appreciated
michaelkenward
Nov 14, 2023Guru - Experienced User
ShyHigh420 wrote:
Got a dos attack on this router ....
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
ShyHigh420
Nov 14, 2023Aspirant
- michaelkenwardNov 15, 2023Guru - Experienced User
Interesting.
Another interpretation would be that those reports are artefacts created by Netgear's logging system, which is known to be problematic.
- microchip8Nov 15, 2023MasterYour ISP is really not going to DoS you. It's a false positive, like 98% of the rest.
If Netgear can't mend this logging system, it should put those logs out of their misery and kill them off.
I have never seen any official response form Netgear. It doesn't even warn people that warnings are mostly rubbish, which is why we get people turning up here scared witless by them.
