ShyHigh420's avatar
ShyHigh420
RAX35
Got a dos attack on this router had to manually block the services port 67 and not 443 since that is dhcp and IP. So if anybody has any issues I suggest you check your logs and see if you have any ip...
  • ShyHigh420's avatar
    ShyHigh420
    Nov 14, 2023
    ok so I went with your option and did a whois and is was my isp abusing a port and sending dos attack: fraggle attacks so I ended up copying the logs to send to comcast on this website https://internetsecurity.xfinity.com/help/report-abuse they mitigated the issue now thanks for your help much appreciated
