fryon1031
Jul 16, 2020Initiate
RAX35/40 (firmware: V1.0.3.80_1.0.1) issues SSID, PPPoE
I upgraded the firmware to V1.0.3.80_1.0.1 today and many things went wrong... 1) I am unable to change the SSID in admin mode (192.168.1.1) I change the SSID names & passwords for both 2G a...
Christian_R
Jul 17, 2020NETGEAR Employee Retired
Hello fryon1031,
May you revert back to the previous firmware version and let me know if there is any improvement.
Thanks,
Christian
- fryon1031Jul 17, 2020Initiate
Downgrading the firmware worked but I had spent more than 3 hours trying to get this set up with the newest firmware. I suggest that you check all the features before releasing a new firmware.
- ob123Aug 15, 2020Initiate
Reverting back to older firmware fixes the issues with WIFI disconnect. Waiting for Netgrear to fix the problem with next firmware version.
