MrMarvin7
Jan 11, 2022Initiate
RAX35/40 v1 now usable with .94?
Hi All, Like many other users of the RAX35/40 v1 routers, I gave up on it after a slew of bad software, lack of support and communication. I recently re-read another forum post, RAX40 Firmware 1.0....
RangerX
Jan 12, 2022Apprentice
I actively posted in the "RAX40 Firmware 1.0.3.80 Crash/Bug Log" thread during those difficult times of getting a non-working router (RAX35v1) working with some level of reliability and with the all the features advertised for the router actually active and available.
Firmware version .94 did work reliably with all features enabled and available (I can only speak for the features that I am using though). But QOS is not functional (or at least doesn't appear to be since it gives no status information) and Remote Access has been removed. I ran .94 for many months with no issues.
I recently installed firmware version 1.0.4.102 which apparently was a security fix release. I have not noticed any problems with it so far. I installed on top of .94 and lost no settings and the router restarted with no problems. I have noticed one smart device having some issues lately connecting to the Internet and responding, but other smart devices have no issues so at this point I think it is not a router problem but am monitoring the situation.
Definitely make a backup of your setings before doing any update to firmware. Also download the current version of your firmware so that if the update fails and you do not have access to the Internet you will have the previous version locally available to reinstall on your router.
Hope this helps.
