bringo
Dec 06, 2020Guide
RAX35v1_V1.0.3.88_1.0.1
I see netgear just released a new firmware RAX35v1_V1.0.3.88_1.0.1. Has anyone applied and experienced any problems. My last firmware update was HELL and i had to restore back to the old firmware. Post any problem you have with the new firmware. i want to confirme is good before applying. Netgear is horrible with the firmware update....they cause so much problem and hell.....
- Eagle-TwoApprentice
I have a RAX35v1 that is running 1.0.3.62. I will be updating it to 1.0.3.88 soon. I had connection issues with 1.0.3.80 so I had to roll back to 1.0.3.62 and then disable AX.
Let us know how it goes after updating to V1.0.3.88_1.0.1. Also If you do end up having connection issues on the latest firmware could you try disabling AX mode and see if that fixes it.
- bringoGuide
please do let me know how the update goes....i really wanted to know before i applying...thks
I updated to 1.0.3.88 a few days ago and performed a factory reset. So far I haven't had any issues even when AX is enabled. I will keep you updated.
