Cru26
Jan 17, 2024Aspirant
RAX35v2 - Firmware v1.0.16.132 - Internet Download/Upload Speed by Device stats not refreshing
Since the upgrade to the latest firmware, I'm observing that I'm having issues with the data in the Attached Devices view refreshing properly. It appears to be retaining the max values for Internet D...
Jan 17, 2024Guru - Experienced User
Might try a factory reset on the router and setup from scratch then see if the values remain or get refreshed.
Happens in different browsers as well?
Cru26
Yes, multiple browsers. How will a reset potentially fix this? It was working fine before the firmware update.
This seems more like a caching issue or something in the firmware.
- FURRYe38Jan 17, 2024Guru - Experienced User
Maybe. Something a FR could help clear out.
- Cru26Jan 17, 2024Aspirant
The prior stats were cleared with a reboot, then they seem to have gotten stuck again with a different attached device. I can try a FR, but that's a PITA since I've got some custom config in place. Guess I just need to restore it, so maybe I'll give it a shot later today when I'm not working.
When you have time. Take a snap snot back up first before you start the FR.
