AC2020's avatar
AC2020
Follower
Dec 18, 2020
rax35v2 : lost cable connection when LED showed super busy
I have the updated version of firmware. After I replaced with this AX WiFi6 router I kept loosing cable connections. When it happened, the LED showed busy signals. WiFi worked fine. I did not have th...
