alsina86
Jan 28, 2023Aspirant
RAX35v2 disassemble
I want to know how to disassemble it. if there is some guides or videos...
- Jan 29, 2023
There's not guides but you can look at the fcc info and it gives you a better idea of where the screws/attachment points are.
I couldn't find the RAX35 but the RAX40 is pretty similar in case wise. Might be helpful.https://fcc.report/FCC-ID/PY318300430/4152853
Jan 28, 2023Guru - Experienced User
Not herein the forums.
Unless it's broke or long out of warranty, would not be recommended.
Might find some information out on the internet.
Usually there are screwed under the routers rubber feet.
