alsina86
Jan 28, 2023Aspirant
RAX35v2 disassemble
I want to know how to disassemble it. if there is some guides or videos...
- Jan 29, 2023
There's not guides but you can look at the fcc info and it gives you a better idea of where the screws/attachment points are.
I couldn't find the RAX35 but the RAX40 is pretty similar in case wise. Might be helpful.https://fcc.report/FCC-ID/PY318300430/4152853
Jan 29, 2023Guru - Experienced User
- alsina86Jan 29, 2023AspirantI was able to do it thank you very much for the help! I will be adding some heatsinks to avoid the wifi drop
- FURRYe38Jan 29, 2023Guru - Experienced User
Might I suggest a laptop cooler fan under the router as well for additional 24/7 forced are cooling. I keep on under any router I have online. Been doing this for years now. Help keeps things cool and helps with HW longevity as well.
